2000 Dodge Intrepid rpms
97,000 MILES • 6 CYL • 2WD • AUTOMATIC
MANNING_4667
My 200 Dodge Intrepid ES after it has been driven for just a little bit the engine starts to jump and vibrate and the RPMs with constinly move btween 500 to 2000 when the vehicle coms to a stop.
Mar 19, 2010 at 12:37 PM
MERLIN2021
  • 17,250 POSTS
Get a can of spray Throttle body cleaner, start the car and spray around, pay attention to vacuum lines and manifold, if the idle changes, you found a leak. You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs!
The other possibilty is the idle air control, it,s bolted to the side of the throttle body...
Keep the spray off the exuast manifolds! Fire hazard!
Mar 21, 2010 at 9:06 AM
