2000 Dodge Intrepid plastic front dam
MRCARS
Other Category problem
2000 Dodge Intrepid 6 cyl Automatic 52000 miles
I pulled off part of the plastic dam on the front end of my Intrepit. Can I take the remaining part off/ Will it cause problems? If yes where can I get a new part? Thanks
Feb 11, 2008 at 4:55 AM
BMRFIXIT
  • 19,053 POSTS
[quote:03170c0ddb="mrcars"]Other Category problem
I pulled off part of the plastic dam on the front end of my Intrepit. Can I take the remaining part off/ Will it cause problems? If yes where can I get a new part? Thanks[/quote:03170c0ddb]
Its design to maximize the air flow throw the radiator area
it may not effect you but then again it may its all depend on your driving
try to use a plastic tie to hold it togther
Feb 12, 2008 at 10:20 AM
MRCARS
I try fixing as suggested . Found black ties at Walmart 20 for 1.38.
Feb 13, 2008 at 12:46 AM
