2000 Dodge Intrepid Overheating and now Dead
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
TWICEINALIFETIME.LUNA
I was having problem with my the engine of my Dodge Intrepid overheating... It went on for a few days and I tended to the coolant system respectfully, but one day, I came to a stop in traffic at an intersection and it died... It hasn't turned on since. Coolant is still in the tank, and when I try to start the engine. I don't even hear the ignition.
May 30, 2010 at 5:21 PM
BLUELIGHTNIN6
  • 16,542 POSTS
is the engine cranking over at all or just getting a click when you try to crank?
May 30, 2010 at 5:27 PM
I am hearing absolutely nothing when I turn the key in the ignition...
May 30, 2010 at 5:28 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check your fuses. are the headlights, radio etc.. working?
May 30, 2010 at 5:45 PM
I opened her up again today in hopes of stumbling across the answer. I did in fact check the fuses and they all looked functional after close observation.
May 30, 2010 at 5:47 PM
BLUELIGHTNIN6
  • 16,542 POSTS
and the electrical systems, are they working?
May 30, 2010 at 5:49 PM
I did not check the above mentioned... i.e. radio.
However, I do know that the power locks are working...
May 30, 2010 at 5:51 PM
BLUELIGHTNIN6
  • 16,542 POSTS
seems as though ignition switch may failed, will need to have charging system and starter tested
May 30, 2010 at 5:52 PM
