2000 Dodge Intrepid noise on turning
112,500 MILES • 6 CYL • FWD • AUTOMATIC
STRYKER
when I take off and cut the wheel to turn a corner the left front makes a squealing noise. not like metal on metal. like something is rubbing together. Noise stays the same not louder when you go faster. Now it does it for a few seconds on straight line take off. i almost have it pin pointed, just not quite. Was thinking power steering pump/bearing hub or something in linkage. not the brakes/rotors, just changed those....any ideas?
Mar 24, 2010 at 3:41 PM
CH112063
  • 1,320 POSTS
Tire noise? Air pressure ok?
Mar 25, 2010 at 3:32 PM
STRYKER
tires/pressure good, really think it may be power steering pump. got it to squeal a little every time I hit the gas quick from stand still..... pump or belt. thanks though.
Mar 25, 2010 at 4:08 PM
CH112063
  • 1,320 POSTS
I just thought of that tire noise you hear on the cop shows all the time. The pump isn't very serviceable but belts make some really strange sounds sometimes. let me know how it goes, your welcome, no problem.
Mar 25, 2010 at 5:51 PM
