2000 Dodge Intrepid no commpression
141,000 MILES • 6 CYL • FWD • AUTOMATIC
DLEEGONE
  • 6 POSTS
The timing chain is in place, but the car has no compression. The car turns over and tries to start but wont.
Dec 1, 2008 at 3:56 AM
DOCFIXIT
  • 18,828 POSTS
The motor is an interference engine that means if chain is off and engine rotated pistons hit valves. Did chain go while driving or was crank turned during replacement? Yes to either question bent valves
Dec 1, 2008 at 5:29 AM
DLEEGONE
  • 6 POSTS
No bent valves, timing chain in place and tight, could it be a broken cam?
Dec 1, 2008 at 5:40 AM
DOCFIXIT
  • 18,828 POSTS
Do the valves move?
Dec 1, 2008 at 5:54 AM
DLEEGONE
  • 6 POSTS
Yes valves move, cam not broken, gonna have to give to mechanic, Im $800.00 in it and haven't found the problem.
Dec 2, 2008 at 1:35 PM
DOCFIXIT
  • 18,828 POSTS
What is compression per cyl? is it 0 or low on all cyl?
What prompted the chain replacement?
Dec 3, 2008 at 12:01 AM
DLEEGONE
  • 6 POSTS
chain wasn't replaced, water pump was which is connected to chain. some valves have 30 psi and another 60psi.
Dec 3, 2008 at 2:09 AM
DOCFIXIT
  • 18,828 POSTS
Before you removed chain was engine TDC all marks lined up? Was chain tensioner removed? When installed did crank gear line up with mark about5 o'clock and where cam gears at top on mark?
Dec 3, 2008 at 8:03 AM
