2000 Dodge Intrepid Intrepid won't start
58,000 MILES • 6 CYL • FWD • AUTOMATIC
INTREPID WOES
I have a 2000 Intrepid. A couple of weeks ago the heat stopped working. I took the heating/ac fuse out for a few moments and put back in. Heat works great. Took a trip and put approx. 3000 miles on vehicle and it ran great. No problems. Heat quit working again. This time I merely shut heat off while driving and turned back on. Started working again. Today, tried to start the car, it fired for about 2 seconds and shut off. Now, vehicle will not start.
Feb 21, 2009 at 1:02 AM
BMRFIXIT
  • 19,053 POSTS
check fuses
Check if security light on and or blinking
check fuses and relays ASD relay
check for spark
check fuel and fuel pressure
let me know what missing
Feb 21, 2009 at 1:50 PM
INTREPID WOES
Thanks for the tips. However, yesterday, I got the car running. I did this by pumping the gas pedal several times while turning the car ignition over in. I know that this probably isn't the best thing to do with a fuel injected car. My wife also reminded me that this was not the first time this has happened.
Feb 22, 2009 at 12:35 AM
BMRFIXIT
  • 19,053 POSTS
Cycle the ignition key ON OFF ON OFF ON
if have any troubled codes it will show in the odometer area
or it will say DONE
let me know if have any
its not normal to step on gas to start the fuel injected car
Feb 22, 2009 at 1:56 AM
