2000 Dodge Intrepid heater problem
DMUNN
2000 Dodge Intrepid 6 cyl Front Wheel Drive
I have no heat--blower is working and antifreeze tests fine? what could be possible problems?
Oct 22, 2008 at 6:53 AM
  • 110,248 POSTS
Hi:
You will need to have the heater core checked. Is the engine running at a normal operating temp? Also, you may want to check the heat switch to make sure it's allowing heat to enter the car.
Nov 8, 2008 at 9:41 AM
LEGITIMATE007
  • 5,121 POSTS
I agree with jacobandnickolas, also you may want to check your thermostat too .could be stuck closed
Nov 9, 2008 at 10:42 PM
