2000 Dodge Intrepid Heater and air conditioning switches fr
2000 DODGE INTREPID
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
MIKE4344
With the heater or air conditioning on, the air flow will intermittantly switch between the vents and the bottom, with the switch set to vent.
Dec 22, 2008 at 3:08 AM
  • 110,244 POSTS
Hi:
Does this seem to happen when the engine is under a load? To me it sounds like a vacuum leak in the system. The control panal receives vacuum from the engine and then distributes it to different locations based on your needs. If there is a leak, there isn't enough vacuum to keep a switch where it belongs thus it changes direction.
Now, it could be the switch or a bad hose. Check for leaks to the vac hoses (listen for leaks... hissing). Most common areas include near the firewall and under the hood. They use plast hose for routing and it can melt.
If you can't find a leak, you may want to remove the switch and have it checked for a leak.
Let me know how this works out for you or if you have any other questions.
Merry Christmas,
Dec 24, 2008 at 1:36 PM
MIKE4344
Does seem to happen when under load. I'll check the lines for a leak.
Thanks!
Dec 24, 2008 at 3:25 PM
  • 110,244 POSTS
Hi:
If it happens under a load, you have about a 99% chance it's a vacuum leak.
Let me know what you find.
Dec 25, 2008 at 3:51 PM
