2000 Dodge Intrepid Front end shimee
165,000 MILES • 6 CYL • FWD • AUTOMATIC
BUYITUSED
1. Steering wheel shakes/shimees, most noticible while driving at less than highway speed
2. Steering wheel appears to be about 15 - 20 degrees left of center when traveling on straight road...out of alignment?
3. front tires, notably right side low on tread. Don't see any steel belts coming through.
Aug 13, 2009 at 12:38 AM
MAINEIAC65
I had the same problem on an 02 and it was the upper tie rod bushings where they attach to the steering box. Appox. $19 if you fix yourself.
Aug 26, 2009 at 7:07 AM
