2000 Dodge Intrepid car not starting
KNOKE
Engine problem
2000 Dodge Intrepid Engine Size unknown Front Wheel Drive Automatic 170000 miles
When I try to start the car, the display lights all blink and I hear a corresponding intermittant sound from the car. It doesn't even begin to turn over. It doesn't seem to be a battery issue. What is wrong with it?
Dec 29, 2007 at 2:12 AM
ROWTIEAR
  • 91 POSTS
Try your headlghts , are they nice and bright?
If your battery voltage is low your dash lights can do all kinds of wierd things.
Check your battery voltage if you have a volt meter
If not try and boost it and see if the results are the same.
Respond with results.
Dec 29, 2007 at 2:23 AM
