2000 Dodge Intrepid brake light
RMLEWIS5
Electrical problem
2000 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
My rear brake lights will not go off
Dec 13, 2008 at 11:53 AM
  • 110,248 POSTS
HI:
Most likely the brake light switch has come loose under the dash, or has shorted out.
IT's located on the brake pedal under the dash. Make sure when you release the brakes, the button on the switch is closing. If it is, unplug it and see if the lights go out. If they do, replace the switch.
Dec 13, 2008 at 4:27 PM
