alternator replacement?
ATLANTA_BOY678
I bought a new battery , because i always needed to jump my car to get it to start, but now i think its the alternator because i still need a jump with the new battery. what do i need to do?
Sep 27, 2008 at 11:53 AM
SQM
  • 6,383 POSTS
Just to clarify, when you jump the car does it run without any issue?
Do you only need jump when the car sits overnight?
If you had a faulty alternator, the car will not stay running for very long. A defective alternator will drain the battery then the car will stall. It will also give you a low battery warning light before stalling.
If you only need the jump after the car sits overnight, then you might have a parasitic draw in the electrical system. A parasitic draw refer to a drain in your electrical system caused by a faulty electrical component. Like a dome light staying on overnight or a faulty window switch that draws power all the time.
There is a simple way to test for parasitic draw.
You might find this article helpful:
https://www.2carpros.com/articles/car-battery-dead-overnight
Here is a helpful video that shows the basics of finding a parasitic draw.
https://youtu.be/z5F7WpgjaRs
Jul 28, 2021 at 3:02 PM
