2000 Dodge Intrepid
ANTHONIA
Electrical problem
2000 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
i recently changed the engine for a new one, after being fixed, the car refuse to start, not passing current, it only rolls when ignition is turned
Jun 13, 2009 at 6:39 AM
JDL
  • 16,098 POSTS
Hello, are you saying it cranks good, but, won't start? Or it won't even crank?
Jun 13, 2009 at 8:19 AM
ANTHONIA
when ignition is turned, it tries to crank but does not start as if the fuel isnt getting to the engine
Jun 14, 2009 at 7:12 AM
JDL
  • 16,098 POSTS
If it cranks good but won't start, have a helper crank it, while you check for spark at the plugs and injector pulse. Use a gage check fuel pressure.
Jun 14, 2009 at 7:33 AM
ANTHONIA
there is no spark on the plug and the fuel injector is not fired.
Jun 14, 2009 at 9:45 PM
JDL
  • 16,098 POSTS
Hello, can you check for codes? Also check for primary voltage at he coil and injector/s plug, with the engine cranking. If there is no voltage check the circuits at the asd relay.
Jun 15, 2009 at 1:27 AM
ANTHONIA
I WILL GO AND DO THAT AND COME BACK TO YOU. MANY THANKS FOR YOUR HELP
Jun 15, 2009 at 6:47 AM
