1999 Dodge Intrepid Speedometer, Gear Selection, Transmissi
ETCAL
Electrical problem
1999 Dodge Intrepid 6 cyl Front Wheel Drive 97555 miles
My car is a 1999 2.7 intrepid.
My car will not shift out of low, The speedometer, and gear shift indcator does not work.
I have checked all fuses in the kick pannel and under the hood. I did not detect and bad. To be on the safe side I replaced the PRDNL fues on the upper left I also tested the port for power everything there seems fine.
Feb 23, 2009 at 1:16 AM
MERLIN2021
  • 17,250 POSTS
You can try a self-diagnostic test. To activate self diagnostic program:
With the ignition switch in the OFF position, depress the TRIP and RESET buttons.
While holding the TRIP and RESET button turn the ignition switch to the ON position.
Continue to hold the TRIP and RESET buttons until the word CODE appears in the odometer windows (about five seconds ) then release the buttons. If a problem exists, the system will display Diagnostic Trouble Codes (DTC's). If no problem exists, the code 999 (End Test) will momentarily appear.
Post all codes found.
Feb 23, 2009 at 7:04 AM
ETCAL
the only word that appeared was "trip"
Feb 24, 2009 at 12:45 AM
MERLIN2021
  • 17,250 POSTS
You may need to scan for "B" codes with a Chrsler compatabile scan tool, your other gauges work?
Feb 26, 2009 at 5:33 AM
ETCAL
Im sorry but I had to go to a different web site that answered in a timely fashion w/in the day.
Alan
I feel I have been robed of payment
Feb 26, 2009 at 6:18 AM
