1999 Dodge Intrepid ROUGH IDLE & OIL LIGHT FLICKERS
106,000 MILES • 6 CYL • 2WD • AUTOMATIC
FATBOY2006
My 1999 Dodge intrepid 2.7L. Idles rough,and the oil light flickers at idle. When under acceleration the car runs great,but after a 50-60 mile drive the car will not start for about 1-2 hours.
I have no trouble codes,and i hooked up a vacum gauge and it holds steady at 17..I am going nuts!!!
Apr 21, 2009 at 10:07 AM
  • 110,244 POSTS
The oil light may be coming on because the RPMs are getting too low and causing the oil pressure to drop. Have you checked the fuel pump pressure?
Apr 29, 2009 at 6:37 AM
JHILL8601
Im having the exact....EXACT same problems out of my 99 intrepid!Any luck? because I've taken mine to 4 different shops and put over 1300 dollarz into it! Driving me absolutely insane!
May 25, 2009 at 9:39 AM
