1999 Dodge Intrepid RADIATOR FANS
ABELC
  • 12 POSTS
Engine Cooling problem
1999 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
SHOULD BOTH FANS COME ON DURING NORMAL OR HOTTER OPERATING TEMPERATURE, OR JUST ONE? ALSO SHOULD A FAN COME ON WHEN THE A/C IS TURNED ON?
Mar 8, 2010 at 3:51 PM
CARADIODOC
  • 34,408 POSTS
A fast way to test for proper operation of the radiator fan is to unplug the two-wire coolant temperature sensor while the engine is running. The fan will turn on in a few seconds and will turn off a few seconds after plugging it back in.
If you have a separate ac condensor fan, it might not turn on until the compressor cycles on.
caradiodoc
Mar 9, 2010 at 6:24 AM
