1999 Dodge Intrepid radiator
IMHEATHER
Engine Cooling problem
1999 Dodge Intrepid Engine Size unknown Front Wheel Drive Automatic 83000 miles
somehow, someone put a hole in my radiator with a screw. now the radiator is leaking trans fluid. am i pressed to fix it or can i continually add fluid for the life of the car?
Mar 10, 2008 at 12:01 PM
BMRFIXIT
  • 19,053 POSTS
you have two choices
replace radiator or install tranny cooler
and eliminate tranny cooler at the radiator
what strange is that it should be leaking coolant too
check the leaking area
Mar 11, 2008 at 12:56 PM
