1999 Dodge Intrepid P0750 Shift Solenoid A
1999 DODGE INTREPID
115,000 MILES • 6 CYL • FWD • AUTOMATIC
BUFFALOHENRY
My Intrepid jumps into "Limp Mode" after warming up and throws two codes.. a P0700 and P0750 Shift Solenoid A. I've changed the input speed sensor with no change in condition. Any ideas ? Where IS the Shift Solenoid A ?
Thank you
Feb 16, 2008 at 11:14 PM
BMRFIXIT
  • 19,053 POSTS
[quote:783a3423b8="BuffaloHenry"]Transmission problem
1999 Dodge Intrepid 6 cyl Front Wheel Drive Automatic 115000 miles
Thank you[/quote:783a3423b8]
do you have a black box with about 6 or so wire connected to it by the dip stick that is the solenoid pack
very common to fail
good luck
Feb 17, 2008 at 12:23 AM
BMRFIXIT
  • 19,053 POSTS
in respond to your PM
changing the fluid and filter is a good idea
but I don’t think its going to help clearing the problem
solenoid pack is the problem 9 out of 10
PS make sure you use a ATF+3 tranny fluid
when your filling it
good luck
Feb 17, 2008 at 12:38 AM
