I have a noise coming from my front driver side area. The symptoms of a noise such as a popping/clunking and a little bit of a shaking happen when I apply my brakes or driving on rough roads. I took it to a shop and they told me it was my bad alignment and tires. So I bought new tires and had an alignment, and that did not fix the problem. Since that we've replaced the half shaft, sway bar bushings and caliper bolts. The inner and outter tie rod end looked fine and felt stiff so we did not change them. Not sure if its in the brake system or suspention. Any help with this matter would be greatly appriciated.
Mar 21, 2008 at 5:46 PM
