1999 Dodge Intrepid No compression
1999 DODGE INTREPID
EVAN_WEILAND20
Engine Mechanical problem
1999 Dodge Intrepid 6 cyl Two Wheel Drive Automatic
I have a 1999 Dodge Intrepid. It has no compression when trying to start the engine, and wont start at all. I was told it's the rings on my pistons. If that is true wont I get atleast some compression and fire? How can I know?
Jun 29, 2009 at 12:25 PM
  • 110,244 POSTS
Regardless if you need rings, there would be some compression. Did you check it yourself? Did it actually have 0 psi in each cylender? Did you check for a broken timing belt?
Jul 6, 2009 at 4:57 PM
