car has been running fine. but now the speedometer isn't working and it won't shift gears and the check engine light has now came on
Jun 1, 2009 at 2:36 AM
JDL
✓Experienced Mechanic
hello, if you can, check for all codes. There maybe a tcm code, transmission control module. The fix info I looked at, says, they usually replace the input and out speed sensors first, where applicable. If you replace the tcm, it will have to be reprogrammed with your tire size, you may have to take it to a dealer.
