1999 Dodge Intrepid My Intrepid won't start
MIRA.WILLIAMS
  • 1999 DODGE INTREPID
  • 6 CYL
  • FWD
  • 154,000 MILES
My intrepid will not start. One day I was coming back from work and it just stopped on me. It wasn't knocking or anything it just stopped. It makes a whining sound when you try to start it up but never starts. What could it be and is it worth fixing?
Monday, February 22nd, 2010 AT 11:00 AM
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Monday, February 22nd, 2010 AT 10:57 PM
