1999 Dodge Intrepid jerking
SCKITTELZ
1999 Dodge Intrepid Automatic 171000 miles
Every once in a while when I'm driving my car jerks slightly. It started jerking when I was driving over 50 mph then it started doing it at lower speeds and now it is doing it while i'm at a stop sign or stop light. All my fluids are good. Why is it jerking and is it ok to still drive it while it's jerking?
Jun 24, 2010 at 10:35 AM
  • 75,988 POSTS
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jun 24, 2010 at 6:34 PM
