Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Intrepid
Engine
Symptoms
Idle Erratic
1999 Dodge Intrepid Idle Fluctuating Problems
1999 DODGE INTREPID
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
MOJO15
MEMBER
1 POST
I have a Dodge Intrepid that surges at a dead stop with the A/C on or off. In park, I experience the same problem. Any suggestions? Thank you
Jul 28, 2008 at 12:33 PM
Experienced Mechanic
Could be oxygen sensor, idle air control motor, throttle position sensor, EGR valve, vacuum leaks and fuel pressure problems-
Jul 28, 2008 at 1:00 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
