1999 Dodge Intrepid Hood release handle Defective
MRGOOODWRENCH
Interior problem
1999 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
How do i open my hood when the hood release handle/cable is broken.
Feb 14, 2009 at 4:31 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The cable usually snaps at the handle itself.. if this is the case then just grab some pliers or vice grips and pull the cable to release hood latch. If it is broken at the latch then you will have to use a flat tool to go up from underneath vehicle and push in latch to release hood or if cable is still long enough try and reach it from under vehicle and pull.
Thanks for using 2CarPros.com!
Feb 14, 2009 at 4:33 PM
