1999 Dodge Intrepid got hot
141,000 MILES • 6 CYL • AWD • AUTOMATIC
OLDMAN70
  • 7 POSTS
i was driven and it started to get hot, i pull over and i turn the engine off, when the engine got cold i tryd to start it and it would,nt
Aug 7, 2009 at 5:53 AM
  • 75,988 POSTS
I assume that it is cranking over but will not start if so do below to determine if its a fuel or spark problem and get bak asap with some results
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
No crank at all/nothing
Could mean battery and connections, starter, starter relay, transmission range sensor and ignition switch
Aug 7, 2009 at 10:06 AM
