1999 Dodge Intrepid Fuel Pump or Fuel Pressure Regulator
14,000 MILES • 6 CYL • 2WD • AUTOMATIC
A-AMEY
On my dodge Intrepid, I have had one friend say I need to replace the fuel pump and the other says replace the fuel pressure regulator. My symptoms are: doesn't run as well when fuel is below 1/4 tank or when the temperature drops below 50 degrees. Also, it makes some weird noises when running. The main concern is when starting it; it won't start on the first turn but if I turn the key 3 times it will start just fine.
The car has 140,000 miles on it however it has a newer motor that only has about 40,000 on it.
If one of these is the problem, how much should I expect for repair costs?
Sep 20, 2010 at 6:14 AM
  • 110,248 POSTS
I need you to check the fuel pump pressure and pay attention to pressure drop off. Here is a how to:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find. Also, if you need the fuel pressure gauge, most parts stores will lend it to you.
Sep 20, 2010 at 6:34 PM
