1999 Dodge Intrepid fuel
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
SHAQFU103
not getting enough gas how can i tell if its the fuel pump, fuel filter or fuel injection system
Mar 23, 2008 at 5:36 AM
  • 75,988 POSTS
You need to perform a fuel pressure check by using the correct fuel pressure gauge designed for your fuel system with and w/o vacuum to the pressure regulator then comeback with the readings.
Mar 23, 2008 at 8:37 AM
