not getting enough gas how can i tell if its the fuel pump, fuel filter or fuel injection system
Mar 23, 2008 at 5:36 AM
✓Experienced Mechanic
You need to perform a fuel pressure check by using the correct fuel pressure gauge designed for your fuel system with and w/o vacuum to the pressure regulator then comeback with the readings.
