1999 Dodge Intrepid Flashing lights
1999 DODGE INTREPID
118,000 MILES • 6 CYL • FWD • AUTOMATIC
JERRY KAY
The interior lights (map lights, courtesy lights) flash off and on while driving. Additionally, at night so do the headlights. This could be dangerous since the cars in front think you are flashing at them! Only the car is doing it, not the driver. Any help? Dodge dealer says it will be very costly to diagnose.
Thanks!
Apr 28, 2009 at 2:49 AM
  • 110,244 POSTS
Does the car have an alarm system? IF so, factory or aftermarket?
Apr 29, 2009 at 6:25 AM
JERRY KAY
No alarm, factory or after-market.
Apr 30, 2009 at 12:19 AM
  • 110,244 POSTS
It sounds like a ground problem. Make sure the ground to the engine block is clean and tight. Also, check for ground straps to the body of broken or rusted ones. If all is good, have the body control module (BCM) tested.
Let me know what you find.
Apr 30, 2009 at 7:16 AM
