1999 Dodge Intrepid Enginge problems
1999 DODGE INTREPID
88,000 MILES • 6 CYL • 2WD • AUTOMATIC
KDJANTZ
What would the cost be to repair a blown head gasket or cracked head?
Car emits white smoke from tail pipe, heater takes a long time to warm up and shakes while driving and pick-up is slow, could this mean it is a blown head gasket or cracked head?
Thank you, concerned MOM for daughter's car.
Oct 30, 2008 at 5:02 AM
  • 110,240 POSTS
Hi:
Yes, white smoke is usually an indicator that there is coolant geting into the combustion chamber. The most common reason is a bad head gasket; however, a cracked head could do it too.
To replace the head gasket, it will most likely be around 3 to 4 hundred dollars. If the head needs replaced, a used one would run aprox. 150.00 dollars.
Keep in mind, I don't know where you live, so it's hard to estimate the labor cost per hour.
I hope this helps.
Nov 4, 2008 at 5:02 AM
KDJANTZ
As it turned out - the dealership found it to be a bad thermostat and housing unit. Thanks for your input :)
Nov 4, 2008 at 5:10 AM
