1999 Dodge Intrepid Engine stops
10,200 MILES • 6 CYL • FWD • AUTOMATIC
AMARCHETERRE
  • 5 POSTS
While driving car, engine shuts off without warning!
Dealer suggests replacing fuel pump.
Replaced fuel pump, and throttle body sensor.
Still will not start.
There are so many sensors in this car, not sure where to go from here.
Aug 30, 2008 at 8:16 PM
BMRFIXIT
  • 19,053 POSTS
check for spark
i would check timing
check /replace crank sensor
check /replace ASD relay
let me know
Aug 30, 2008 at 11:11 PM
AMARCHETERRE
  • 5 POSTS
Thank you for your quick response,you have been helpful. I did replace the ASD relay with the fan relay(same part) the car runs short distance and shuts down. Not sure how to check the timing, any help with that would be great.
At this point, I'm thinking the ECM, but would like any input before spending a lot more money.
Thank you again.
Sep 2, 2008 at 12:52 AM
BMRFIXIT
  • 19,053 POSTS
go for a crank sensor
Sep 2, 2008 at 5:54 AM
AMARCHETERRE
  • 5 POSTS
Hello, made the suggested repairs, replaced ASD, replaced crank sensor. Car will start, but still shuts down. The last time it shut down, the internal lights flickered. ECM?
Sep 4, 2008 at 1:49 PM
BMRFIXIT
  • 19,053 POSTS
i dont remember if u checked for codes !
lets cycle key ON OFF ON OFF ON
read codes in odometer area
after its stalls ,does it start
or it take s time
mark relays and switch them around
Sep 4, 2008 at 10:51 PM
AMARCHETERRE
  • 5 POSTS
Replaced relays with new, switched them around, no change.
Car generally starts right up after shut down.
Some bucking and light flickering before shut down.
Code read P1684.
Sep 5, 2008 at 2:32 AM
BMRFIXIT
  • 19,053 POSTS
Battery power was disconnected PCM had a lose of power
I would try and clear codes
(by using a scanner and check for codes again)
if no codes take it for a run test and if and or when it stall on u,
check for codes
if the same code come back we may have power failure to the pcm and need to check connectors and wires check pins for any green in them sign of corrosion
Sep 5, 2008 at 4:48 AM
AMARCHETERRE
  • 5 POSTS
Before battery was disconnected, the codes that read were P0113 and P0123
Sep 5, 2008 at 7:24 AM
BMRFIXIT
  • 19,053 POSTS
P0113 Air temp sensor and p0123 TPS volts high
p1684 code came after U disconnect the battery!
and if so then I would not worry about it for know
drive it and let check if any other codes comes back after stalling
Sep 5, 2008 at 8:53 PM
