1999 Dodge Intrepid engine failure
102,000 MILES • 6 CYL • FWD • AUTOMATIC
KAHNE9
I recently purchased a 1999 Intrepid with 102000 miles on the engine. After driving less than 200 miles the engine failed . I had another engine placed in the car and in less than 300 miles the engine failed. Is there a major problem with these engines.
Feb 24, 2008 at 10:34 AM
BMRFIXIT
  • 19,053 POSTS
what size engine you have?
in general they are a good engines
what is the reason for failure
Feb 25, 2008 at 9:33 AM
KAHNE9
2.7 V6 not sure what made them fail
Feb 26, 2008 at 8:44 AM
BMRFIXIT
  • 19,053 POSTS
check timing it may jumped on you also check the cam and crank sensors if they in sync you need a scanner for that
try this disconnect the cam shaft and crank car to start
good luck
Feb 26, 2008 at 8:57 AM
