1999 Dodge Intrepid cruse control
65,837 MILES • 6 CYL • FWD • AUTOMATIC
BEEP
cruse was intermittent would set and resume. After time the dash light goes out and quits working. Is this a function of the PCM. Dodge dealer does not know and cannot fix problem.
May 19, 2009 at 7:42 AM
ZACKMAN
  • 4,202 POSTS
Usually cruise control problem is caused by either vacuum leak or bad speed servo.
May 19, 2009 at 6:10 PM
BEEP
The unit stops working when the dash light goes out. For a time if the engiine was shut off and restarted it would work again. Now the dash light does not come on at all, that's why I think it is electrical. Both speed sensors have been replaced for shifting problems.
May 20, 2009 at 3:34 AM
ZACKMAN
  • 4,202 POSTS
https://images.2carpros.com/forum/automotive_pictures/55316_99intrepidcruise2_1.jpg
https://images.2carpros.com/forum/automotive_pictures/55316_99intrepidcruise3_1.jpg
Do the easiest thing first. Check fuse #1 at the end of driver side dash. You may also want to check the cruise clock spring. While it may seem electrical, I would still check the servo and its vacuum. The PCM uses the info from the servo to actually make the cruise controller work.
May 21, 2009 at 3:49 PM
