1999 Dodge Intrepid CRUISE CONTROL
1999 DODGE INTREPID
134,000 MILES • 6 CYL • FWD • AUTOMATIC
TERRORRNER
hi there. when trying to get my cruise control to work, i get up to atleast 35mph, keep a steady foot on the pedal, push the cruise button to "on" and then push "set" . the cruise will not pick up so i can take my foot off of the gas pedal though. whats the way to fix this ??
feel free to email me w/ answers.
terrorrner@yahoo.com
amanda
May 9, 2009 at 8:00 AM
CARADIODOC
  • 34,383 POSTS
Does the green "Cruise" light on the dash turn on? If not, suspect a broken clock spring under the steering wheel. If I'm right, eventually the "Air Bag" light will come on, and the system will be deactivated, and the horn will quit working too.
caradiodoc
May 9, 2009 at 6:13 PM
TERRORRNER
In reply to caradiodoc's question, yes the green cruise control light does come on.
i was told from the previous owner that the cruise is finicky and will work when it wants to.
amanda
May 10, 2009 at 12:29 AM
CARADIODOC
  • 34,383 POSTS
Sorry for the long delay.
Since the light on the dash comes on, the clock spring is ok, and all the other switches should work. First, try pressing the "set" button while pulling the brake pedal up with your foot. If it works, suspect a brake light switch that's out-of-adjustment.
There could be a defective "set" switch. On some models, you can press the "decel" switch, and it will set at the speed where you released the button. Not all models work like that. On some, you must press the "set" button first before the others will respond.
Check the electrical connector on the servo for corrosion on the pins, and inspect the vacuum hose for cracks. I have run into a couple of defective servos in the past. One had a solenoid wire that wasn't properly soldered by the manufacturer. This is a common servo found on a lot of Chrysler models. You should have no trouble finding them in a salvage yard.
caradiodoc
Jun 1, 2009 at 9:01 AM
