1999 Dodge Intrepid brake booster
1999 DODGE INTREPID
ELDONDEACON
Brakes problem
1999 Dodge Intrepid 6 cyl Two Wheel Drive Automatic
How do you replace the brake booster? Car has new brake shoes, has no leaks, but brake pedal goes all the way to the floor. All air has been removed from cylinders and lines.
Mar 5, 2010 at 1:30 AM
  • 110,244 POSTS
The brake booster will not cause the pedal to go to the floor. If there are no leaks and the rubber brake hoses are good, chances are you need a new master cylender.
Let me know what you find.
Mar 18, 2010 at 3:43 AM
