1999 Dodge Intrepid
NAVINRAJ
  • 1999 DODGE INTREPID
  • 6 CYL
  • FWD
  • 185,060 MILES
HI. THIS IS RAJ I HAVE A DODGE INTERPID 99 I HAVE A PROBLEM WHILE THE ENGINE WAS RUNNING IT AUTOMATICALLY STOPS AGAIN AFTER 5MIN. CRUNIKING IT AGAIN STARTS ITS TAKES TWICE A DAY. BUT IT DOESNT SHOW ME ANY CHECK ENGINE.R ANY LIGHTS SHOW ON MY DASH BOARD. SO IWENT NEAR BY MECHANIC SOME SAYS ITS BATTERY PROBLEM. SOME SAYS ITS ALTERNATOR PROBLEM TODAY I WENT TO AUTO ZONE HE TOLD ME THAT U HAVE TO TUNEUP UR VECHILE. SO CAN U GVE ME REPLY. WAT TO DO.
Saturday, March 20th, 2010 AT 8:43 AM
MATHIASO
  • 1,209 POSTS
Hello navinraj
Starting with tune up will be the right way to go until your engine runs normal again.
There is no engine light, or there is code or the engine light bulb burned out.
Have it scan and ask them to look for trouble codes and for pending codes.
Check battery sate of charge.
2.68v.......... 100%
12.45v.......... 75%
12.24v.......... 50%
12.06v.......... 25%
11.89v.......... 0%
The charging system should produce about 13.5 to 14.5 volts at idle.
Low voltage can adversely affect the operation of the ignition system and fuel injectors, causing stalling and misfiring
beside those, check the coolant sensor, A weak ignition coil or a faulty crankshaft position sensor may also cause a stalling problem, If the stalling started to occur shortly after your last fill-up, suspect bad gas.
Sunday, March 21st, 2010 AT 5:09 PM
