1999 Dodge Intrepid
TJARMY
  • 1999 DODGE INTREPID
1999 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
i just bought a 99 intrepid off a friend. He took it to a mechanic who told him the head gasket was blown, upon removing the heads we found the water pump was bad. After replacing all components together with new pump and gaskets the motor wont start, we are getting fuel and replaced the plugs. We followed the repair manual but are stuck on what is keeping the motor from fireing but it will turn over
Sunday, June 21st, 2009 AT 6:37 PM
  • 109,872 POSTS
Are you getting spark to the engine? Have you checked fuel pump pressure? If both are good, recheck engine compression and timing.
Let me know what you find.
Monday, June 22nd, 2009 AT 10:28 PM
TJARMY
Yup getting fuel and spark im getting spark now im wondering if when I put the engine back together if I missed timed it? I have a tech manual to work on it, just a tad more complicated than my bronco to work on
Tuesday, June 23rd, 2009 AT 7:19 AM
  • 109,872 POSTS
IF you are getting spark and fuel to the engine, then either the timing is out, or there isn't enough compression for it to start. Do you have a gauge to check the compression?
Tuesday, June 23rd, 2009 AT 1:54 PM
