Engine Mechanical problem
1998 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
my 3.2 intrepid was running fine then it just quit. It cranks good fuel pump is running, I pulled a plug and no fire
Saturday, September 25th, 2010 AT 2:12 PM
MECHANIC
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
