1998 Dodge Intrepid wil not start
CLAYTON WILLIAMS
  • 1998 DODGE INTREPID
1998 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
My intrepid 98 stalled on the road and will not start it sputtered once then nothing else any ideas on what would cause this?
Tuesday, May 11th, 2010 AT 8:03 PM
Do below basic checks to determine if its a fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Tuesday, May 11th, 2010 AT 8:38 PM
