1998 Dodge Intrepid trouble bleeding coolant system
1998 DODGE INTREPID
50,000 MILES • 6 CYL • FWD • AUTOMATIC
NIKKI082106
been trying to bleed coolant system opened bleeder screw filled coolant alot of air coming out just keeps coming never comes in steady stream. had to replace parts from air in coolant system what could be the problem...thank you
Apr 11, 2010 at 9:57 AM
CH112063
  • 1,320 POSTS
You'll need to pressure test it for leaks, it may need more bleeding then your able to give it if one of the cylinder heads or gaskets are leaking internally. This is a big problem on any older car. I'm sorry I can't be more precise and many times the heads must be removed to find the problem. But it is done every day. Today I am absolutely sure of because of the way my back feels. It effects the heater also, sorry. Always replace the head gaskets in pairs. ok nikki
Apr 13, 2010 at 1:53 PM
