HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Intrepid
Ignition
Timing
1998 Dodge Intrepid timing balt
CRAIG WIEGAND
MEMBER
1998 DODGE INTREPID
6 CYL
FWD
AUTOMATIC
203,487 MILES
How do you set the timing belt thank you
Monday, March 1st, 2010 AT 2:48 PM
BLUELIGHTNIN6
MECHANIC
2.5L
3.2L and 3.5L engines
Monday, March 1st, 2010 AT 6:16 PM
Please
login
or
register
to post a reply.
Related Ignition Timing Content
Proper Timing Settings
My Neighbor/friend Is Taking Me Thru Replacing The Head Gasket. We Didnt Set The Motor In A Specific Position Before The Teardown Began. I...
Asked by
2010stu
3 IMAGES
2002
DODGE INTREPID
2003 Dodge Intrepid Timing
I Just Recently Changed The Water Pump And Timing Chain On My 2.7 L '03 Intrepid. The Marks On The New Timing Chain Are Lined Up With The...
Asked by
RPAC
2003
DODGE INTREPID
2001 Dodge Intrepid Timing
I Need To Get Timing Done On My Car, Mechanic Says Not To Do It, Better Of To Put New Engine In It, Because Type Of Engine It Is....
Asked by
sammiey6
2001
DODGE INTREPID
Timing Check
What Is The Correct Procedure For Checking The Timing On A 2003 Dodge Intrepid 2.7l Engine?
Asked by
blkgolfer1
2003
DODGE INTREPID
Timing
Have A 2004 Intrepid With 3.5l Engine. Timing Belt Broke And When I Installed A New One, And Re-set The Timing, I Get Compression On The...
Asked by
mysliwy
2004
DODGE INTREPID
VIEW MORE
Low Engine Power
Symptoms of Low Engine Power
Fix an Engine with Low Power!
