1998 Dodge Intrepid steering wheel
158,000 MILES • 6 CYL • FWD • AUTOMATIC
UMBBA
items connected to the steering wheel are not working. Horn and cruise control. Checked fuses not the problem.
Sep 19, 2009 at 8:45 AM
CH112063
  • 1,320 POSTS
If the underhood and interior fuses are ok the fastest step would be to check the horn button under the air bag. See if it works when you ground it.It may be common under or in the column. Did you check this with a scan tool and make sure the body control module does not show any problems? OK
Sep 21, 2009 at 11:42 AM
