1998 Dodge Intrepid Noise when i turn my wheels
18,300 MILES • 6 CYL • FWD • AUTOMATIC
T3PROTAC
When i turn me wheels, when moving or parked, there is a loud clunk/thunking sound coming from the drivers side wheel. From what i have read most people say this is a CV joint problem, but looking at my CV joint the boot is still in great condition. I am wondering if this could be the strut bearing gone bad. If so: Is there any down side to just replacing just the one bad side with a "quick strut" complete assembly? If I do put on a quick strut do i need to worry about alignment problems, since i wont be turning the tie rod at all?
Sep 16, 2010 at 8:03 AM
BMRFIXIT
  • 19,053 POSTS
You can replace just one strut as for the alignment replacing the strut will change the alignment
https://images.2carpros.com/forum/automotive_pictures/99387_int_1.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_intr_1.jpg
check inner tie rod end bushings
Sep 16, 2010 at 12:30 PM
T3PROTAC
Does this sound like the strut bearing or the CV joint?
Sep 16, 2010 at 3:41 PM
BMRFIXIT
  • 19,053 POSTS
CV axle makes clunking as you drive and turn not standing still
jack tire up and check side to side and up down
Sep 16, 2010 at 11:31 PM
