car over heated, check coolent , added about 2 liters, over flow was full. leak in top hose to over flow, car runs fine, no white smoke from exhaust, leaks slowly when not running. wondering if this rules out the leak being internal, like head gastket etc. am i fine to drive it as long as I keep coolent in it. until I locate the leak. there is no visible leak. it only over heated at high speed not at idle I asume this ment it was circlating the coolent it had. does this rule out stuck termostate, and h2o pump not pumping. does a wet spot on passengerside floor mean heater core is where the leak is? thank you very much for your time.
Aug 31, 2009 at 6:30 AM
