1998 Dodge Intrepid fuel leak top rear of engine
1998 DODGE INTREPID
370,000 MILES • 6 CYL • FWD • AUTOMATIC
R0D
i think its at the fuel rail how do i get to it?
Jul 12, 2010 at 3:32 PM
  • 110,194 POSTS
You need to remove the plenum to access that area. Please keep in mind, any fuel leak is dangerous. Also, chances are it isn't the fuel rail but an injector or rubber hose.
Jul 16, 2010 at 11:20 PM
R0D
[quote:9e9b281e9f="Jacobandnickolas"]You need to remove the plenum to access that area. Please keep in mind, any fuel leak is dangerous. Also, chances are it isn't the fuel rail but an injector or rubber hose.[/quote:9e9b281e9f]
I actually pulled out the cross support [between strut towers] found the plastic high pressure in line cracked,dealer says line from tank to rail, but looking at repair kits but only listed to 2007,you'd think u could cut n stick some hi press line in place of the plastic?
Jul 17, 2010 at 8:51 PM
  • 110,194 POSTS
They do make high pressure rubber fuel line, but if you try to tighten it on the plastic, it will crush the plastic and leak. Are you sure it is going to the tank? If I recall, that is a steel line.
Jul 18, 2010 at 1:25 AM
