1998 Dodge Intrepid Fog Lights
11,700 MILES • 6 CYL • FWD • AUTOMATIC
JFIU528796
I have a 1998 Dodge Intrepid, on which I would like to install OEM fog lights.
Since this vehicle did not come equipped with this option, I was wondering what addition parts I would need to purchase in addition to the OEM lights themselves.
Do I need to run additional wiring?
Do I need to change the headlight switch, or is there an additional switch?
Does Dodge make an add-on kit? If so what is the part number?
Thanks,
Apr 22, 2008 at 8:06 AM
01INTREPID
You can install a factory fog lights to your 1998 intrepid. check out www .LHFORMS. NET and you'll find a "HOW TO" directions on what all you will need to do and how to install those fogs onto your intrepid. You will also find tons of info on more mods you can add to your intrepid like a overhead display showing miles per gallons, miles till empty, direction and outside temp.....
Apr 22, 2008 at 2:17 PM
