1998 Dodge Intrepid Engine won't crank
WNOWICKIZ1
  • 1998 DODGE INTREPID
  • 6 CYL
  • 150,000 MILES
My Mom's 1998 Dodge Intrepid won't always turnover. It happens randomly, wet, dry, hot cold, etc. When she turns the ignition the dashboard lights come on, but nothing else happens.
She has waited and tried again and sometimes it starts.
She has it at her mechanic now, any ideas on loose connections, bad relays, interlocks or other things that mght fit these symptons?
Thanks
Tuesday, April 21st, 2009 AT 6:52 PM
  • 109,885 POSTS
It could be a relay, starter. If you still had it I could have you check some things, but if it is at the mechanic, I can't. When they tell you what is wrong, let me know and I'll tell you if it sounds logical.
Wednesday, April 29th, 2009 AT 7:15 PM
WNOWICKIZ1
They could not find anything, so they gave it back. I told her to try to start the car in neutral the next time it happens.
Other checks?
Thursday, April 30th, 2009 AT 5:12 AM
  • 109,885 POSTS
Yes, if it doesn't start in neutral, have a helper turn the key to the start position and check to see if there is 12 volts of power going to the smaller wire on the starter. There should be when the key is in the start position.
Let me know what you find.
Thursday, April 30th, 2009 AT 2:21 PM
