1998 Dodge Intrepid does'nt shift to the next gear
1998 DODGE INTREPID
ANGRYMAN
Transmission problem
1998 Dodge Intrepid 6 cyl Automatic 49000 miles
I got this 1998 intrepid with only 49000 miles, it was crashed in the front driver side. I replaced the power stering pully and new belt. I then checked for any leaks, saw none so i put the car together and took it for a test drive, it drove well except that the RPM had to go 3.5 for me to go 45 mph? I hooked it up to a code reader and it gave me 2 codes P0700 and P1768 then i spoke to a friend and he said that it has something to do with the transmission not going to the a higher gear. Can you please help me.
Apr 10, 2008 at 2:52 AM
BMRFIXIT
  • 19,053 POSTS
since it was in a crash I would check the tranny wiring harness and also check for power at the TCM and its wiring too
start with fuses
Apr 11, 2008 at 11:02 PM
