1998 Dodge Intrepid Cooling fans electrical connector
BUCKLESPLUS
Engine Cooling problem
1998 Dodge Intrepid 6 cyl Front Wheel Drive
The cooling fan connector from the wiring harness to the driver's side fan is melted and the fan is inoperable. Is this connector available in the parts after market or strictly a dealer item? If so it may be easier to direct wire it to the ignition circuit so it runs whenever the engine does.
Jul 22, 2009 at 3:02 PM
  • 75,988 POSTS
it may be easier to direct wire it to the ignition circuit so it runs whenever the engine does. Watch yourself with voltage drop on this.
Why don't you identify the wires and splice in-if the harness connector is not available
Jul 22, 2009 at 10:43 PM
